How can I find out this angle grinder model/brand? The label has come off so I dont know the model. The grinder is not working and I believe it is the brushes, how can I know what brushes to buy if I dont know the brand or the model? I was able to read something I believe it is "Pa6 ge30"
[img]https://image.ibb.co/jamo5a/17373171_1500457109989280_506947401_o.jpg [img]https://image.ibb.co/fyrSyv/17351223_1500456736655984_406501642_n.jpg [img]https://image.ibb.co/ktT1Qa/17430704_1500456806655977_787717601_o.jpg [img]https://image.ibb.co/iNQ4dv/17392696_1500456909989300_2107525600_n.jpg [img]https://image.ibb.co/bRWMQa/17410313_1500456943322630_1658083182_n.jpg [img]https://image.ibb.co/gUzVJv/17408258_1500457016655956_1132823352_o.jpg [img]https://image.ibb.co/ms6XWF/17408100_1500457046655953_1457825632_o.jpg
Few thoughts...
I don't recognize it, so can't be directly helpful.
Pa6 is usually just a reference to the plastic; not sure about the ge30 part.
You might get lucky by pulling the existing brush/holder and going to a good repair place to see if they have something you can work with.
Have you checked the switch? Failure there would make this a write-off, even with a positive identification.
I'm not a fan of throwing stuff away, but realistically, grinders are a dime a dozen. You can get a name brand used one for about triple what a set of brushes would cost you. You can get a bargain bin (ie, will only work for a little while) one for about the same as a set of brushes.
  • Thank you, I will have to check the switch and try going to a repair shop. Yeah I didn't want to throw it away cause I am on a tight budget
    – Diogo
    Mar 19, 2017 at 20:43
