I would like to connect an iDevices WIFI wall switch to an end of line single pole connection which controls the my table lamp connected to an upper wall outlet. The wifi switch has a red, black white and ground. My wall switch has a black, white and ground. The white is the load (hot wire) coming into the switch.
I know there's a way to do this but I can't seem to find a diagram on line.
My question is in the title: How do I connect a WiFi enabled wall switch?
