I noticed some water seeping up from the ground inline of my water main and to my surprise, under the grass was another valve that I never knew was there. It is PVC and about 3 feet after the main shutoff valve at the street.
It is 1" PVC with a PVC ball valve going to the water meter I assume. The valve has a pinhole leak and I need to replace it. I've replaced many sprinkler pipes before but never anything to do with the water main.
My question is do I repair this line with a normal PVC ball valve and normal PVC glue or do I need to use something else in this situation?
