We have a 23x12ft room that we are looking at opening up the flat ceiling. The 2x6 rafters are parallel with the long side the the room and there is one beam (3 2x6s) that seems to be a rafter tie running this long length of the room. Looks to have a 2x6 coming down from the peak of the roof at the ridge board down to the beam.
The ceiling joist 2x4s are running at right angles to the beam and rafters across the 12ft span of the room. These joists are below the beam and are tied to it by 2x4. We were told that the joists are not providing structural support and were merely for affixing the flat ceiling.
We had hoped to remove these joists and wonder if the 23 ft beam of 3 sandwiched 2x6s (board seams are staggered) will have any sagging/structural issues if we did. Are there structural concerns with removing these perpendicular ceiling joists?
There are collar ties at in the top third but no other rafter ties besides this beam.
