Up front, my question is...how do I most easily and safely check to see if my ceiling fan is grounded?
Now for the explanation. I recently installed 2 identical ceiling fans about a day apart in my two spare bedrooms. Both had fans in them previously; I'm sure they are properly secured in the ceiling. The question arose from when I was installing the second fan. Barely looking at the directions, I came to the part where it was time to properly ground the fan.
As I was pigtailing the two green wires and the bare copper ground together, I had an "uh-oh" moment where I don't remember doing this for the first fan. I feel like I only pigtailed the two green-sheathed wires together and the bare copper is up there unattached somewhere. I may have done this, but I don't remember.
I've already tested them both to see if they work, no problem there. I know touching any metal part of the fan would give me the answer (wink-wink), but I of course don't want to risk being wrong. Is there any easy and SAFE way to determine if it is grounded, or alternately could someone tell me the most efficient way to disassemble the fan the least to accomplish this?
I really do feel like I probably did it right, following the directions religiously the first time. It was just a weird feeling during the installation of the second fan to have that uh-oh moment. I just want the easiest route to being assured.
I thank you for your responses.
