What are some causes/solutions for poor drainage?
It seems that our house tends to drain water very slowly. The bathroom sink could probably overflow if the water was left on, the bathtub also seems to take a while. Even the kitchen sink seems to drain slowly (though turning on the garbage disposal seems to help).
I've already poured Sulphuric acid down the bathtub, but that hasn't made much of a difference that I could tell.
edit:
We have public sewer
  • Do you have a septic system, or a public sewer? – Tester101 Aug 8 '10 at 20:46
Since all of your drains are slow, you could have blocked or broken connection to the sewer system. There are companies you can hire that will come in and put a camera down the drain pipe so you can see blockages or breaks. It's been quite awhile since I had it done, so I can't remember exactly what it cost, but it seems like it was $200-$300.
  • A common cause of blocked and broken sewer connections is that some trees or cactus growing above your sewer line have burrowed their roots into the pipe. A plumber snaking your main cleanout would pull up dirt and roots if this were the case. – indiv Sep 2 '10 at 6:38
  • If you cut the roots be sure to use a root killer product in order to make the work done last longer. – Dano0430 Apr 20 '15 at 20:07
My initial thought is that the proper venting is not established is your plumbing system. You need to have "air behind water" to allow everything to drain properly. Essentially it is just a vent pipe that leads to your roof so that pressure does not build up and slow the draining of your sink/tub. Just like how you would punch two holes in the top of a juice can to allow it to poor smoothly... the second hole acts like a vent. Reference: http://en.wikipedia.org/wiki/Drain-waste-vent_system
    I didn't know that's what that was for - I've seen it in my parents house and just assumed it was for some other reason, though I can't remember it now... – Wayne Werner Aug 9 '10 at 10:00
Try something like Draino or Liquid Plumr - both are alkaline bases, which may dissolve a clog that an acid won't.
For the tub especially, you may want to try just taking off the cover (if there is one) and looking to see if there is hair or something blocking it - it is easiest just to remove the stuff you can manually, then put a drain clog remover down.
If it's a worse clog, you can try using a snake, like this or this one.
I'm going on the assumption that it's not the entire house that's a problem here, but it could be your main line clogged (though you'd also be having problems with toilets, in that case).
  • I'll have to pick some up today to see if that'll work. – Wayne Werner Aug 9 '10 at 10:01
  • This happened to me. I tried all sorts of chemicals and none seemed to work. I assumed it was something more serious, but it turned out to be a bunch of hair clogging the drain. I ended up using a tool called a Zip-it. A $3 solution I wish I would have tried earlier! – Andrew Jun 24 '12 at 7:14
I would not try Drano or other harsh chemicals as these are only slightly effective if the clog is close to the drain. When all drains are draining slowly, the first step is to check the main drain and sewer lines. You can usually find a plumber that will include a video camera check and sometimes this is free if you are using them to make the repair.
