A few days ago, I got a letter from the HOA telling me that I have to replace the warped, twisted, sagging 2x4s forming the roof of my pergola.
I have absolutely zero confidence that any PT 2x4 I buy from Home Depot or Lowes won't warp/twist/sag the exact same way within a matter of months, let alone years. Three weeks ago, I replaced the first one with a normal 16' PT 2x4 from Home Depot as a science experiment. I didn't have to wait long for the results.... it's not even a month old, and it's ALREADY bowed.
I did more research, and discovered LVL (and LSL and PSL) engineered studs. Except nobody seems to make a 2x4x16' (1.5"x3.5"x16') stud that's officially approved for outdoor use.
The boards won't ever have to support any weight besides their own, so life-safety and code-compliance aren't concerns. However, I've also seen what happens to OSB and particleboard when they get wet.
From what I've gathered, PSL swells when it gets wet, and never goes back to its original form... but Weyerhauser has a product (Parallam Plus PSL) that supposedly IS marketed for submerged use. Unfortunately, the smallest size you can get is 4x10 (3.5x9.25), and apparently you can't just take a 4x12 and slice it into multiple 4x2 pieces with a table saw.
I read on another site that LVL studs will swell and cup when wet, but return to their original straight form once they dry out. I got a quote on Boise-Cascade Versa-Stud LVL from Home Depot, but when I talked to Weyerhauser's support rep, he was ADAMANT that it could not be used outdoors (but wouldn't elaborate on whether it was because it would swell/warp/disintegrate, or just a matter of regulatory approval).
Has anybody seen what actually happens to a LVL (like Versa-Stud) when it gets used somewhere that's directly exposed to the elements (albeit painted)? Likewise, if I sliced a Parallam Plus into multiple faux-2x4s and used them instead, would their APPEARANCE be compromised, or would they just be useless for loadbearing applications (but perfectly capable of supporting THEIR OWN weight if they're just laid horizontally on top of a pergola)?
I actually did a second simultaneous experiment 3 weeks ago... I took two 1x2 6' strips and glued & screwed them together to make a 2"x2"x6' homemade glulam. It warped into a graceful arc that would be pretty if it were intentional, but unfortunately renders it unusable for its intended purpose (a straight 1.5" x 1.5" x 6' board, to replace the original PT 2x2s that all eventually warped and bowed at one or both ends)
I'm definitely open to other suggestions, if anybody can think of a better alternative to standard 2x4x16 PT studs. I looked at cellular PVC, but the ones I found were either a) not strong enough to support their own weight aross a 10-foot span without sagging, or b) so breathtakingly expensive, I didn't even get to the point of investigating their sag-resistance.
As far as cost goes, I can live with spending 2-3 times as much as I'd have spent on regular pressure-treated 16' 2x4s if I can feel confident that they'll look good for at least 8-10 years.
Update #2
Re the suggestion to use cedar. Home Depot can order it, and the nominal price per board isn't bad... until they hit you with a $79 surcharge for lumber special orders under $700, which completely nukes the economics of buying 10 boards, and risks total expense meltdown if I ended up having to place a second order to get a few more.
Other ideas I'm currently exploring (but not really satisfied with):
Attempting to use two short in-stock cedar 2x4s fastened end-to-end with a pair of mending plates. Not something I really want to do, because it wouldn't save much money and would probably look awful.
Using PT 2x4s, with added bracing... a 1-1/2" x 1/8" x 8-foot aluminum plate screwed into one side of the new boards that are laying flat to strengthen the 10' unsupported span.
Yeah, I'm at that dangerous, frustrated point where I'm roaming Home Depot looking for anything I can creatively repurpose as an exoskeleton to brace a 2x4... vinyl trim strips, steel stud tracks... ;-)
Update #1
Re the suggestion to reduce the span. In theory, I could possibly add a third pair of horizontal beams parallel to (and halfway between) the existing two and reduce the unsupported span from 10' down to about 4.5'. Two problems, though:
The "house" side of the beams is fastened to the front wall of the house with what appears to be a custom-machined steel bracket. I know Simpsons' Strong Ties would probably be functionally equivalent, but then it wouldn't match the appearance of the original brackets on the two existing beams.
The attachment point ON the front of the house is the front edge of a cast in place reinforced concrete suspended slab. Maybe I'm over-thinking the problem, but I'm pretty sure that the recessed area (where the existing ones are anchored) and the dimple along the underside isn't purely ornamental, and that whatever is behind the dark-brown recessed area is likely to be pretty hard to drill through.
Photos:
Illustration of how the existing beams are anchored to the front of the house
