I'm designing a deck by modifying an existing plan I found. The design features a large triangular projection on the right side, which is supported by a double 2x10 main beam (supported by 3-6x6 posts approx 6'5" apart). There is a secondary beam in the shape of a triangle that is attached to the main beam on the two open ends, with an additional post at the end furthest from the house. My plan is to use a double 2x10 skewed joist hanger to make the connection, however I'm not sure if that is structurally sound or would meet code (Virginia). I wanted to get everything worked out before I go to the plan review.
Thanks!
