I'm remodeling my bathroom and have everything torn down to the studs.
I would like to add some LED lighting to the toe kick of the vanity that is controlled by a switch and I don't want any cords/cables to be visible.
My question is, what's the ideal way to wire this?
Should I install an outlet somewhere in the vanity then plug in the LEDs to it? Is there a solution where i just hardwire the LEDs? Since these are low voltage, is there some other solution?
I know there's a million ways to accomplish this, but wasn't sure if there was a standard way that was being preformed for new construction.
