I want to install some closet rod supports for a double rod closet. My studs appear to be spaced every 16". The rod supports need to be drilled into the studs at heights of 42" and 84". The house is a ranch, this is being done on the ground floor.
The other side of the wall is a laundry room with washer and dryer outlets. I'm worried that the electrical for the laundry may be fished through the studs, and that when I drill into the studs for the rod supports, I might hit the electrical wires.
Is there any way to check how the wires are arranged behind the wall, besides tearing the wall down? Some extra info:
I'm in New York. The wall dividing the closet and laundry room used to be an exterior wall - the room with the closet is an extension from 2009.
Thanks, picture attached.
