I'm running new wiring to add receptacles in an attached garage. I have attic access above the garage and have been drilling down into the top plate into the cavity where the receptacle will go and fishing the wire from above. I came across this section where the top plate is gone, and in its place is some metal flashing and a hollow cavity.metal flashing and hollow cavity
It's about 10" across, and When I dropped a fish pole down the cavity it went down about 29". Tapping the fish pole, it sounds like the bottom is metal. There doesn't appear to be anything in this space (besides some of the blow-in insulation). There is a fire block in the wall, but it's about 10" further down.
The wall is shared with the kitchen on the inside of the house, but there isn't anything in that area except a wire between a couple outlets in the kitchen, about 14" further down than the bottom of this cavity.
The kitchen was remodeled at least once since the house was built, but that was before we bought it, so I'm not sure how the kitchen used to be laid out. For what it's worth, it was built in 1984, in Northern Virginia.
It's right above where I planned to put a receptacle, and I've already cut the hole for the work box. Can I just drill through the bottom?
At one time that metal piece was probably part of a vent pipe to transition a range hood up through the ceiling. If it had been in use there was likely to have been a rectangular to round transition that then piped out through a shrouded roof vent.
Just drilling a hole through the bottom of that metal piece may require a special treatment such as a grommet to protect the electrical wire from the sharp metal edges.
  • Thanks! I think you hit the nail on the head. I was able to find an original floor plan for the house, and there was a cooktop right in that location. Interesting that they to appear to have just vented it into the attic.
    – Matt
    Commented Feb 27, 2017 at 20:45
  • Yeah. Venting only to attic would have been a bad thing. It is possible that the attic section of the venting was removed. You could look at the roof boards near that are to see of there may have been a roof vent at one time. The other possibility is that the cook top may never have made it past the initial construction phase. Especially if the in-wall piece does not have a side cutout.
    – Michael Karas
    Commented Feb 27, 2017 at 22:30
