I just had a plumber install a new shower valve in a remodel and when I run my finger around the back of the ring on the front of the valve, I feel a little bit of moisture. It's a large walk in shower and he installed 2 of these valves but I only feel the moisture on one valve.
Is this normal? Is it maybe that the valve is just sweating a bit?
I did this on 2 separate occasions about 6 hours apart so I know it wasn't an isolated incident.
It's a Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body.
