Ive never done plumbing so im trying to learn some basics. I have this waste pipe (i believe thats what its called) sticking out of the wall. I believe its a 1.5" waste pipe. waste pipe
I want to connect it to this p trap kit i put together. p trap kit
I obviously cannot just stick them together as the waste pipe does not have a threaded connector. wrong way to connect a p trap to a waste pipe
What is it i need to connect the p trap to the waste pipe? I believe it maybe called a waste pipe compression fitting? If thats what i need what size do i need?
Im confused because the ptrap says its 1.5" but the waste pipe is thicker and also i think is 1.5". I think the waste pipe is 1.5" because i can connect another pipe to it to that states its 1.5". And yet the waste pipe is thicker then the p trap. I.e. This image...
1.5" elbow
That t thing in the middle clearly says 1.5 on it (i presume inches).
As a bonus question what kind of adapters do i need to use if the waste drain is not center with where the sink drain will be?
Edit
The fourth picture is just for illustration purposes i dont plan to use the sanitary t. It was just to show what i meant about my confusion between the difference in sizing.
  • By the way, check to make sure the DWV pipe sticking out of the wall is glued-in. The plumber may have just "set" it in place so the drywall installers wouldn't cover opening.
    – Lee Sam
    Feb 23, 2017 at 23:38
  • post a photo of the completed job so we can admire your work.
    – Alaska Man
    Feb 24, 2017 at 4:48
Your forth photo is not correct, the fitting in the photo is a sanitary tee and is not used in that location. there should be one in the wall and that is what the waste pipe is glued to.
Your third image is correct except you need a 1-1/2-in dia PVC Trap Adapter Fitting
to glue onto the waste pipe coming from the wall. It glues on to the waist pipe and has treads to accept the compression nut you have with your p trap kit. You will then slide the p trap pipe into the adapter and compress the washer to the adapter by tightening the compression nut to the adapter.
To account for an off center p trap alignment you can swing the p trap sideways ( if it is not to far off center ) and then adjust the length of the pipe going into the waste adapter. You may need an extension or to cut to length depending on how close you are. If you are to far off center you can use a flexible pipe, i do not like them and avoid them if i can. i prefer to use solid glued pipe and 45% fitting. ( Or a 90% elbow and come at from the side. )
If that is what is required then you need to extend the waste pipe out with a 1 1/2 inch coupling to the distance needed to come into it from the 45% angle, on the end of this pipe you put the 45% fitting then another short section 1 1/2 pipe and the adapter glued on to that so you can run the p trap pipe into it. ( try to make this short section of pipe long enough so that if in the future you have to cut it to make changes you have enough to glue a new fitting to. ) Dry fit everything, this will take some thought and planning, since the p trap is swing-able you have some leeway for the waste pipe extension. Make all your cuts and dry fit it all together BEFORE YOU GLUE. If the distance from the p trap to waste pipe extension is to great you can buy a slip joint extension to bridge the distance. It works on the same compression principle and you cut it to the proper length.
BE AWARE : when you dry fit you can not get as tight a fit as when you glue I.E. When you glue the distance will change slightly because the pipes and fittings will slide further onto/into one another. I try to account for this when i make my cuts but because the p trap swings you have some wiggle room.
There are many angles here and therefor more than one way to skin this cat. Try to keep the number of turns that the water has to make to a minimum to insure a better flow. I find it is better to buy all the fittings and pipe i might possible need and take back what i do not use to avoid multiple trips to the store.
A few options here, and rubber coupler http://www.homedepot.com/p/1-1-2-in-x-1-1-2-in-DWV-Flexible-PVC-Coupling-P1056-150/100058870 or a PVC HUB x SJ trap http://www.homedepot.com/p/1-1-2-in-PVC-DWV-Hub-x-SJ-Trap-Adapter-C48017HD112/100345781
    In the 4th. picture turn the tee 180 degrees, if there is to be a drain coming from above. In the 3rd. picture the fitting you need is called a Desanco fitting. Desanco fittings are used to convert regular pipe to drain fittings with a compression ring and nut ,as you show in picture 2. Then follow what Alaska Man said.
    – d.george
    Feb 23, 2017 at 10:39
