I noticed a wet spot where the ceiling meets one of the walls in my garage. When I went into the attic, I noticed the wet spot under the insulation as shown in the images below. The insulation is wet to the touch near the spot and appears to be taking water in from up and behind where it's tucked in. I reached my fingers up in there and definitely felt water.
I'm guessing it's a roof leak since it only happens during hard rains (here in Florida). I went up on the roof and felt around, but felt like I was searching for a needle as there was nothing immediately obvious.
Not really sure what to do other than just call an expert. Any advice? Thanks.
