What size wire is required to carry 100 amp service from the meter to the panel?
2You seem to have a misspelling in your title. Please edit. Also add details about run length, etc.– isherwoodFeb 22, 2017 at 17:26
2And what country are you located in ?– TysonFeb 22, 2017 at 17:33
Do different countries have safer or less safe ratings for how much current a particular gauge of wire can carry?– fred_dot_uFeb 22, 2017 at 18:15
No @fred_dot_u, different countries have different codes.– Speedy PeteyFeb 22, 2017 at 19:01
1@fred_dot_u I don't think the question can be answered without knowing the country and its codes. Wire will actually carry more than it's typically rated to carry. Insulatation types and availability also vary by country.– TysonFeb 22, 2017 at 23:08
1 Answer
This question has been answered for a 60' distance on the DIY Stack Exchange and provides additional references for longer or shorter runs.
I suggest that the spelling error is the keyboard proximity of the letters C and V and a missing R, indicating that the OP wishes to carry 100 amp service.
1Shrug, Diy has a stealth downvoter of late. It may be because the linked queston doesn't appear at first glance to apply. I see where it does. Feb 22, 2017 at 21:16
The down vote may have been because this question should have been flagged as a dupe of the link in the answer instead of repeating the answer.– FreeManJul 22, 2020 at 16:49
