-1
I normall only turn on one central heating at a time upstairs or downstairs but when accidentally both are on, the minute that happens my water heater pilot goes off. This is proven fact.
I can only think not enough gas as they are all using gas but I have no idea, that was wild guess.
Any idea to this madness? I have searched for any related issues and I have not able to find yet.
If you know solution please share, thanks
    What size is the gas lines that connect the furnaces,the water heater, and the main incoming line. Post a picture or an explanation of the sizes and configuration so we can get a better idea of what is happening. – d.george Feb 22 '17 at 10:16
  • I think there may be an adjustment on the WH so that you can increase the flow of gas for the pilot. Question: If the burner on the WH is on (you just made a large demand for hot water) and one furnace is on, and the other furnace burner is called, will all three come on and stay on? – Jim Stewart Feb 22 '17 at 11:31
The only way to tell for sure would be to measure the gas pressure at the water heater when both furnaces are on. This will require a gauge and probably a little plumbing. The other possibly might be a venting or combustion air issue especially if they are all in the same room or are commonly vented.
