Water supply is off and toilet tank is empty. The bowl keeps filling up with water and is overflowing. Where is this water coming from?
  • What kind of dwelling is this? house, duplex, apartment? Feb 18, 2017 at 16:13
You need to be more specific, is the water overflowing the bowl and running onto the floor? If that is the case then the drain line somewhere below that toilet is plugged and waste water from above the toilet that drains into the same sewer line is the problem. You will need to call a plumber who can figure out where the blockage is and fix the problem
  • Is water coming up through the tub and shower drains too? Sounds like a sewer main is plugged and sewage from uphill is flowing into your house. Find your outside clean-out at ground level and remove the cap. The sewage will flow into your yard. Feb 18, 2017 at 14:43
Open the cap or cover on your sewer cleanout in the yard! If water/sewage comes out, then call the city emergency line immediately. Leave this cap off and let sewage flow into the yard. This will prevent it from overflowing into your house.
