I live in metropolitan Houston, Texas (note: high humidity), and this concerns a home I recently purchased. I have a heater (furnace) and blower unit installed in the attic, which is typical for many homes in Texas.
When I bought the home, I noticed the blower in the attic would always run even if I set the thermostat to off on the wall. I assumed there was something wrong with the compressor or thermostat, but something told me to look in the attic, and then I found this on top of the furnace/blower (I guess it is a combo unit).
Here is a close-up:
The Honeywell switch (I believe it is part of this system, and model number W8150A1001) was previously set to “On,” but then I set to “Override,” and I assume this enabled the wall-mounted thermostat to override that switch, because now the blower will not run if I set the wall-mounted thermostat to “Off.” Problem solved, or so I thought. While I am savings bundles on my electric bill, I am wondering if there was indeed a reason the previous owner had it set to “On” so that it ran all the time. After all, the switch says “On” offers “Optimized Ventilation.” As the switch is currently set to “Override,” do you think this might enable mold growth due to inadequate (i.e., not optimized) ventilation? Should I switch it back to “On”?
