I'm thinking of putting in a single color LED strip for under cabinet lighting and RGB LED strip for over cabinet lighting, both with dimmers. I plan to plug in a power supply above the microwave cabinet which has one plug free, can i connect both LED strips and dimmers onto a single power supply? Of course the paths of current will be separated (i.e first set of red and black wires going down for under cabinet and second set going up for the RGB strip from the power supply). Also, does the type of power supply matter?
I plan to use one of these dimmers for the single color LED strip https://images-na.ssl-images-amazon.com/images/I/51qedrgjUPL.SY355.jpg OR http://www.photo138.com/0/AWS/YC00400-1.JPG
And for the RGB strip, either a 24 or 44 key remote IR controller.
Answers are welcome!
