I have a 20"x60"x3/4" piece of knotty pine with three coats of lacquer. I have two big support brackets. This will be a minimalist desk, should I mount the brackets to the sheet then mount the brackets to the studs in the wall or should I put the brackets in to the studs then lay the sheet over and secure it to the braces? Any pros/cons to mounting it one way over the other?
  • Are you asking simply which order to attach the pieces together?
    – mmathis
    Feb 14, 2017 at 15:52
  • @mmathis yes, do i put the wood on the bracket and then bracket on the wall. OR bracket on the wall, then lay the wood on it and secure it...
    – AM_Hawk
    Feb 14, 2017 at 16:43
As you're just asking about which order to attach the pieces, and not different methods, there is very little difference.
Mounting the brackets to the wall first may make it easier to ensure you hit studs, but you'll have to be careful to make them exactly level with each other. Attaching them to the desk first ensures they are level, but you'll need to measure more carefully to get the spacing right so you hit studs. Neither is really difficult to get right, just different considerations.
It may be slightly easier to hold the brackets in place without a heavy desk on top.
If you are using any kind of joinery to attach the brackets to the desk (other than screws into the underside of the desk), you'll want to do that before mounting it to the wall, of course.
Another consideration is how much clearance you have below the desk; with little or no clearance, you'll have to attach the brackets to the desk first.
