I am planning on installing some LED light strips in a closet full of shelves. I am using an A/C adapter (wall wart, brick, what have you) connected to the strip, which plugs into an outlet. I plan to have the outlet controlled by a light switch to provide on/off to the light strip.
Is it possible to use a motion sensor as the light switch?
Or, is there an easier way to get the LED lights to turn on automatically?
Yes. You can buy standalone sensors designed to switch lights on and off. There are both plug-in switches and ones that you hard-wire to your light fitting.
It depends. You could use a microswitch on the closet door.
Yes. They make 12V motion sensors. They are actually cheaper than 120V sensors because the sensors proper run on low voltage DC, and thus do not need a mains power supply within the sensor. That is the way to do it, if you don't mind the vampire load of the 12V power supply being on all the time.
