What wire size is needed to run 100 amp service 220 feet with no more than 3% voltage drop? Running a fused disconnect off of meter on house out to detached garage.
1Are you running this feeder overhead, in conduit, or as a direct bury? – ThreePhaseEel Feb 13 '17 at 0:02
Nearly a duplicate: diy.stackexchange.com/questions/93718/… and diy.stackexchange.com/questions/74445/… – Ecnerwal Feb 13 '17 at 0:36
Add a comment
