We have a magnetic child lock attached to the inside of the front panel on a kitchen drawer. Over time, due to tugging on the drawer a bunch without successfully unlatching the magnetic latch, we've managed to pull the front panel right off the drawer, and I'm curious what I should do to fix it.
Here's the opening where the drawer normally resides:
the drawer resting on a countertop (minus the front panel):
and the front panel:
The front panel looks fine from the outside, so I'm not opposed to a kludgy fix on the inside to avoid a costly bill to replace the drawer altogether. All the sides of the drawer appear to be made of dense particle board, and this includes the piece that attached to the front panel and connected to the other sides via staples, so I'm not surprised this cheap construction eventually gave way.
Here are some more photos of what happened, starting with the backside of the front piece (the child lock is the white piece towards the left, which in hindsight, I should have mounted closer to the handle):
and close-ups of the way it attached to the sides:
My initial thought was to pull out the staples still embedded in the sides of the drawer, carefully re-attach the front panel to the sides using wood glue, and then use metal corner braces to reinforce the inside corners of the drawer. Would that be a bad idea?
