We have a leak in the bathtub faucet that needs to be addressed, but getting to the main water shutoff is located in a crawl space beneath the adjacent unit.
Is it okay if I shut off the cold water supply to the hot water heater for a few hours, while I repair the tub faucet?
When I turned it off just briefly, it started making an almost pressurizing noise, which had me a little worried. Might have just been the water retreating down the piping, but I wanted to make sure
    Turning off the cold water supply to the water heater won't do anything to the cold water supply at the tub faucet...
    – mmathis
    Commented Feb 7, 2017 at 22:19
  • @mmathis Yes, but the faucet leak is severe enough that the water heater's H20 supply will deplete pretty quickly if I can cut off it's intake. Once it's drained, I'm assuming I can begin work. I've gathered that I should shut off the water heater itself initially
    – Jimbo1128
    Commented Feb 7, 2017 at 22:25
    @Jimbo1128 -- what about the cold supply to the bathtub faucet? Commented Feb 7, 2017 at 23:50
Yes, but...
  • Turn off the water heater first. You don't want the elements heating without a full tank. Be sure to fill it completely before turning it back on.
  • Expect some residual pressure for a bit. Open a few taps low in the house to help.
    And by "fill completely" that means open hot water faucets and wait until air stops coming out with the water. Only THEN should you turn the water heater on.
    Commented Feb 7, 2017 at 22:47
