I want to light a cabin.
I have the following:
  • 75w 12V Coleman solar panel (two bare wire ends)
  • Large car battery from a Jeep
  • Even larger (boat?) battery - an Optima Yellowtop 34/78
  • 50/10/2A 12V battery charger
  • 100w AC/DC car inverter
My cabin will be unoccupied most of the time, so my thinking was to use the solar panel to trickle-charge the battery(-ies) over the week, and then use the batteries to power the lighting - either LED or incandescent with the inverter.
Budget is minimal so although LED lighting would be simple, we already have mains light bulbs so perhaps using the inverter is an option to avoid having to purchase LED strips.
What are my next steps to charge the battery from the solar panel? What can I use, and do I need anything else?
  • The voltage is a bit low to fully charge a 12V battery. More information would be needed to point you in the correct direction for next steps. Are you asking how to wire? type of lighting? it is not clear.
    Feb 6, 2017 at 14:51
  • Your solar panel could be wired straight to the battery, but a voltage regulator would be best put in line between the 2. The deep cycle marine battery (boat battery) will be your best option. The inverter would be for hooking the lights to. But you might also consider 12v LED lighting. This would eliminate the inverter, and allow you to power your lights for days without charging. The battery charger you would have for backup in case the sun doesn't shine enough, but assuming you have no power now for lights, how would you power the charger?
    – Jeff Cates
    Feb 6, 2017 at 15:08
  • @EdBeal I edited my post with more detail
    – Dagrada
    Feb 6, 2017 at 15:09
  • @JeffCates I didn't know I could actually charge the battery directly from the solar panel! Can you point me to an example voltage regulator I could use?
    – Dagrada
    Feb 6, 2017 at 15:13
    Although you already have the main lights with an inverter there are losses converting to 120V . I would find strips of LED's on the internet and use these because you have the DC already and there would be no losses converting from 12VDC to 120AC. I looked up coleman 12V 75W solar and it has a blocking diode so you could connect it to the battery to charge but if the battery is charged on a sunny day the panel will be over charging the battery 4.3A (measurements should be made to verify that the voltage doesn't exceed 14V or a charge controller will be needed to protect the battery.
    Feb 6, 2017 at 15:31
This isn't one of those games where the goal is to use only this bag of parts, right?
Charge the battery with the solar panel
Simply connecting a solar panel to a battery will not do what you want. It will overcharge and wreck the battery. You need a charge controller between panel and battery. This is a keystone product that will make or break your build.
Good ones are hard to find. Generally the ones sold at chain/big-box retail stores are foreign dreck, often with reputable brand names slapped on them. I prefer using a low-end controller from a well-reputed company in the solar business like Morningstar. Unfortunately many of these are specialty products, so you just have to read up on solar-power forums and places like that to see who's regarded as the best.
From there, it's a simple affair to connect solar panel to charge controller, and charge controller to battery.
A good charge controller will not need you to throw switches or change wires.
Hook up your loads
Since your goal is lighting, get 12V lights. The point is to use 12V lighting throughout, run straight off the battery. Don't even think of running an inverter to run 120V lighting, that's just crazy.
Off-grid power is too precious to use anything but LEDs for lighting. Nothing else is efficient enough. You don't want to double your battery and solar just to run CFLs, or 7x your battery and solar to run incandescents. That's just crazy. No, LEDs are not ugly light (more on that). Yes, the government forcing swirly CFLs is unfair, but LED is also winning fair-and-square because it's better.
You can get 12V LED lighting in all sorts of shapes and sizes:
enter image description here enter image description here enter image description here enter image description here enter image description here
Be careful with your choice of color temperature and CRI when buying LEDs. A lot of the early or cheap LEDs had poor CRI and harsh color temperatures, and they got a bit of a reputation. These days you can get any CRI or color temperature you want.
CRI is Color Rendering Index, or how good the light looks to humans; aim for 80 or up (out of 100). Color temperature is how "blue" the light is. The traditional warm incandescent lighting is 2700-3000K (kelvin, weird unit, I know). 4100K is office fluorescent lights. 5100K is a cloudy day, blue-sky is 6500, and that sounds great when you're buying it, but it looks awful at night. Try to have all your LEDs be about the same color temperature.
Other loads
Make a very serious effort to find 12V versions of anything else you want to run. These days a lot of flatscreen TVs are 12V friendly. Boaters, RVers, tiny-house and VanLife people have good sources.
Inverting to make 120V involves a serious amount of energy loss. Even an inverter sitting idle has a fairly high power consumption.
You can't run them 24x7 or they'll destroy your battery. In fact, don't neatly install one. Leave it something you temporarily hook up in a tangled mess, so you'll remember to unhook it and put it away.
Don't overwork the battery
Both your batteries are lead-acid type. That particular type has a serious problem: it *really, really does not like being deep-cycled.** Deep-cycle lead-acids, like your Optima yellowtops, do better -- but they still will be destroyed by deep cycling, just will get more cycles before they do (on the upper range of the numbers I'm about to give).
  • If you drain it dead, you'll get 5-30 cycles before battery death
  • If you drain to 50%, maybe 20-200 cycles
  • if only 25% DOD (using 25% of capacity) many hundreds of cycles
  • 15% DOD thousands of cycles.
Factor this against the fact that lead-acid batteries typically fail anyway after 5-7 years. The upshot is, depending on your usage, you may need a larger battery for this system to make sense. Or...
Other battery types
You may think "Wait, my laptop/iPad/phone doesn't have that problem!" Correct. But before you start salvaging 18650's out of laptop batteries, lithiums have a different problem: spectacular battery fires. To avoid that, you need to build battery packs carefully and include a protection circuit - many people are doing this for off-grid / home-power. There are lots of instructionals out there, some not so safe.
There are more traditional battery types such as the famous NiFe "Edison battery" or its brothers NiCd or NiMH. But you're not going to find those on the cheap.
