Is this possible? Obviously, I have to cut out the drywall to accommodate the new box. Currently this is the set-up: 2 pole light switch image
Ultimately, I need this outlet to contain: 2 light switches and 2 120V receptacles: Switch Plate Config. (I was unable to find a pic for the outlet, could only find switch plate pic). The breaker for the existing switch is 15 amps. Also on the same breaker, a duplex 120V receptacle.
10
    What do you mean by AC switch? A thermostat? Something controlling a window AC? – ThreePhaseEel Feb 5 '17 at 23:09
  • From that switch, you are in North America... but "AC switch" is not a term in common usage here. Jargon terms are difficult to use well; please explain in plain English. Also, please review this about the meaning of "2-gang" etc. and then edit your question as needed. diy.stackexchange.com/questions/11654/… It may be possible to do what you want without hacking drywall, but we need to be clear. – Harper - Reinstate Monica Feb 5 '17 at 23:12
  • Thanks Harper--indeed in USA and will edit my question accordingly. – M.Mat Feb 5 '17 at 23:15
  • Do you mean one duplex receptacle (2 plugs) or two duplex receptacles (four plugs)? – bib Feb 6 '17 at 0:48
    Also, do you know if there's a neutral at this location? – ThreePhaseEel Feb 6 '17 at 1:20
This is a single gang 2 switch unit. By removing the single gang box and installing a double gang box (old work box would be the easiest to install). You could use the same switches and add a duplex receptacle. A standard double gang outlet cover will finish it.
