I have a difficult situation, there is a need to turn the heater permanently off without my father/home owner 'knowing' I did this. On a daily basis he tosses paper products in front of an electric baseboard heater, that is turned up to 70* and is around 160*+ heat emanating. I am terrified of a fire when I go to work or am asleep. There is two heaters in the kitchen area, that are heating the kitchen + Living Room area, where a single baseboard heater that no longer works. So if I somehow achieved shutting off the heater of concern, one remaining heater would be heating two rooms and that entire end of the house.
I have read here one might disconnect, then cap off wires. Or shutting off thermostat. And for the circuit breaker, I would "guess" there is one for at least both heaters. So these things are not a choice.
(I would like to mention am an adult. No need for unnecessary concern in to this matter further than just any ideas one might have!)
Thank you.
    Hello, and welcome to Stack Exchange. If there are separate thermostats, then the heaters might be on separate breakers. Turning off a circuit breaker would be by far the easiest task; try that first to see if there's a dedicated breaker to the heater in question. And, I'm personally doubtful that a surface that never gets over the boiling point of water could actually ignite something. – Daniel Griscom Feb 1 '17 at 17:48
  • Is there a single thermostat that controls that heater? Disconnecting the wires in the thermostat might be an option. Don't make assumptions on the breakers: baseboard heaters can draw a lot of power and that limits the number that can be on a single circuit. – gregmac Feb 1 '17 at 17:48
    FWIW the autoignition point of paper seems to be 424°F. I can find some news articles about baseboard heaters causing fires from electrical cords and drapes hanging on them -- and should note, these articles tend to either say "all occupants escaped safely" or "there was no (working) smoke detector". A reminder to be sure yours work, and even if you do absolutely nothing else, it would be cheap and easy to install a battery-operated smoke detector in the room near this particular heater. – gregmac Feb 1 '17 at 17:58
