I have a Magic Chef Mini Fridge 2 door from Home Depot (HVDR430SE) that doesn't cool. It has no evaporator or condenser fan because it is a sealed unit. The thermostat clicks on, starting the compressor and turning it off also stops the compressor but nothing cools. Is the fridge worth fixing. It's new but I can't return it.
    Why can't you return it? Is it in warranty, and what would it cost to ship to MagicChef directly? Feb 1 '17 at 15:44
  • Is broken, is not made to be fixed - recycle and replace if you "can't return it" or otherwise get it solved (which will be replaced, not fixed) by the manufacturer.
    Feb 2 '17 at 3:49
  • I bought this from an auction for $25. I was hoping it would easily be repaired. Guess not. Feb 3 '17 at 10:27
Throw it away and go buy another, they cost more to fix than to replace.
  • I'm not a big fan of buying another of something that breaks. Maybe pick out a different minifridge. Feb 1 '17 at 15:44
