I will have the following run of cabinets (which will be screwed together and to the back wall) and will install a 20mm (3/4") thick granite countertop over it (with sink and cooktop range).
I've seem people saying that a plywood backer is important, and some other people saying that it is more trouble than it is worth and the cabinets provide enought support as it its. The maximum space between to cabinet walls is about 90cm (3 ft).
