I'd like to glue laminate flooring on my TV wall. I just plan to glue the laminate directly to the wall, which is drywall primed with Kilz PVA
I have No More Nails general purpose adhesive lying around. It states it does not recommend bonding together two (2) non-porous materials.
The back of the laminate flooring definitely looks non-porous. Correct me if I'm wrong, but the Kilz PVA primer makes the drywall non-porous, right?
If so, what would be the best type of adhesive to use for this application?
ANSWERED.
Here are photos of how I did it:
I did end up using some form of adhesive on the aluminum trim/border: Super Glue!
