I have installed recessed lighting in my home.
This is a 3 month old home and I got the light/ fan prewire from the builder
Below are the items I used:
I did check for compatibility before I decided on the lights / dimmers. The light manufacturer's documentation lists the Caseta as a compatible dimmer
On my first floor I have 6 3000K lights with one dimmer and another 4 lights with one dimmer
On my second floor I have 4 5000K lights with one dimmer in 3 locations
All the lights go off of the prewire installed by the builder
I have noticed the below issues :
1) When I turn on the lights they come up nicely with full brightness, but after some time one(just one) of them flickers for a few seconds and then goes back to normal This happens randomly, repeatedly. In one room, 2 of them flicker. I have noticed this behavior in all locations.
2)When I dim them to the lowest possible, one them flickers and eventually goes out completely. The others remain at the lowest level of dimming.
3)When they are turned off and I hit the up button on the dimmer(not the turn on button) all the lights flicker at the lowest dimming capacity and it takes a while for them to turn on
I intend to :
a) reach out to the manufacturers
b) do some testing with another brand of light
In the mean while, any thoughts /suggestions on how I can overcome these issues will be appreciated.
Thanks
