I've had on-and-off problems with sediment in my water lines due to really old city infrastructure. It has clogged the inner workings of the dishwasher, blocked shower heads and faucets, etc. Although the city periodically flushes the lines (or perhaps because they do), particulate still makes its way into my pipes.
Because this is a rental property (I now live about 700 miles away), I'm looking for a solution that would require little intervention once in place (changing filters periodically is fine - I just don't want my tenants to have to constantly clear the sediment traps on faucets or have to worry about appliances that don't have any traps/filtration of their own).
So is a whole-house water filter my best bet? Are there other options I might not be aware of?
Edit: Talked to a plumber, who pointed out the possibility that I may have severely corroded galvanized supply lines after the meter and into the house (which I do). If that were the case, placing a filter before a run of oxidizing steel probably isn't going to do much. It could also be both (the city and my side of the meter).
