We have a tiled shower in the house we just bought. The drain cover is not there anymore.
I bought the drain cover that is closest in size. However, it does not fit perfectly. There is about 1/8" gap all around.
There are two rusted screws I believe on either side of the hole.
At first, I made a ring of plumber's putty and put it on top of the hole...and slightly in the hole. I then sat the drain cover on it and pressed down. I then realized that it is quite soft.
What is the best way to install the drain cover for my shower?
