Running dryer vent exhaust out of side of dryer. Using solid 4" aluminum duct pipe. To seal connections is it better to use regular HVAC aluminum duct tape or mesh with mastic. Have used both in HVAC systems but not in running dryer vents. Any shortcomings or foreseeable problems with either. Thanks
Using mesh and mastic is very important if you want to seal all of your HVAC runs in a house. Tape simply doesn't adhere good enough over time to limit the tiny holes they are trying to cover. It is a big deal to seal a house up right because a properly sealed unit can be 10-20% more efficient - and that is a lot of money for the 2-4 hours it takes to seal it right.
However... your dryer is not part of your HVAC system. It is just a vent going to the outside of your house. The tape is just used to make sure there is a smooth transition so that nothing get caught in your connections (you should not screw in your dryer venting runs to each other). Therefore aluminum tape is the way to go because when you want to clean out your vents you can untape them and retape - hard to do this with mesh/mastic.
  • "you should not screw in your dryer venting runs to each other". Even for concealed duct runs in a wall? – statueuphemism Jan 23 '17 at 22:03
  • @statueuphemism - yes. – DMoore Jan 24 '17 at 4:21
  • Thank you so much for your input!! Will definitely use aluminum tape. You were very kind to answer with such a complete responds. – Alex Jan 25 '17 at 0:30
