The white wall is a party wall in a row house - my plan was just to repair the plaster on the wall. The other wall is an exterior wall that is plaster on brick and mortar. I plan to put up some 2 polyiso board with the wiring underneath as well. Also I will put a new hardwood floor after it is all done. Just want to make sure I am not doing a major no no in regards to the wiring.
If not is the some I can do with the wiring before I finish the walls?
