Does anyone know if non-refillable cartriges of butane or propane have an expiration date? If so, what part from them goes bad?
closed as off-topic by isherwood, Daniel Griscom, ThreePhaseEel, Tester101 Jan 23 '17 at 12:48
  • This question does not appear to be about home improvement within the scope defined in the help center.
If this question can be reworded to fit the rules in the help center, please edit the question.
They do not. Ideally the cartridges are filled with pure butane/propane. The only thing that could go bad is the container around it. As long as the container doesn't show any forms of corrosion it should be fine, there are some butane/propane containers that may leak after a certain period because of a rubber seal inside. The seal can eventually dry out and crack, causing small leaks that will drain the container, even though the gas in the container can't spoil, you wont be able to use it because of the absence of gas
