I bought a new Dewalt miter saw and every time I use it, there is a burning smell. I saw this question about a similar issue, but I don't think my problem is the speed at which I'm cutting or the thickness of the wood (doing test cuts on a 2x2 and have made cuts a varying speeds to make sure I wasn't cutting too fast).
A quick internet search suggests this can happen when the blade is dull or when the blade is on backwards. However, my miter saw actually came with the blade pre-installed, and the teeth are facing the correct way. Also, I don't think the blade a new miter saw comes with would be dull, but maybe I am wrong.
The other thing that puzzles me is I'm not actually seeing burn marks on the wood. Anyways, I was hoping to get some advice on some additional things I could check to determine what is causing this burning smell. Also, are the blades that usually ship with Dewalt miter saws good quality, or should I go ahead and replace it?
  • Re:"are the blades that usually ship with Dewalt miter saws good quality" Dewalt is like many manufacturers. You can spend little and get low-end consumer-grade products from them, or you can spend a lot and get high-end tradesmen tools from them. Jan 20, 2017 at 1:49
    If it is new, it should be under warranty. Find an authorized repair shop near you and bring it in.
    – mikeazo
    Jan 20, 2017 at 2:49
    I own a DeWalt compound miter saw. The first thing I did after setting it up was to replace the blade with a finishing blade (more teeth, smoother cut). The blade it came with was fairly awful.
    – user4302
    Jan 20, 2017 at 6:05
  • Is the blade secured tightly? Maybe you should loosen and re-tighten the blade. Jan 20, 2017 at 17:17
  • yes, it's secured tightly. I am going to replace the blade and if it doesn't fix the issue I will contact an authorized repair shop as @mikeazo suggests
    – foxygen
    Jan 20, 2017 at 20:22
