I have water on the top 4 feet of my basement foundation wall.
This goes around almost the entire perimeter of the basement. The bottom 4 feet of blocks are dry. Any ideas the cause? Can someone suggest a remediation method. FYI the entire wall is below grade. Ground is clay. Grading appears good and downspouts are directed away from the house.
Thanks in advance for any input you can offer....
