Can one use a router to cut wood in a similar way that a jigsaw would cut wood? What are the upsides and downsides of using a router to cut wood?
It seems simple enough, but then again, I've never used either machine. I would think that you could just set the router to a deeper threshold than you usually would, in order to cut through the full depth of the piece. Or perhaps you could flip the piece over after routing one side and finish the cut by routing on the underside.
I ask because it's of course less costly to have one router than to have one router and one jigsaw, particularly for a sporadic user like myself.
