I cut out the subfloor in my half bath on 2nd story above garage. I didn't expect to see 2x4s proving the most support, and just one 2x6 joist. Can someone explain to this newbie what's going on? Thanks.enter image description hereenter image description here
Those are modern engineered floor trusses, or truss joists. They often have flat 2x3 or 2x4 top and bottom chords and a web of diagonals and verticals between.
The 2x you see is a stiffener, or "stiffback", which ties the trusses together to spread load and minimize movement and vibration.
It looks a bit like someone cut out some of the stiffener, maybe to get a duct in the space below. The builder may have added additional stiffeners nearby.
  • Thanks! Would it be inadvisable to block those truss joists with flat 2x4s? So I can install new subfloor?
    – Chris
    Jan 15, 2017 at 12:56
  • Go ahead and add joint blocking wherever you like. Subfloors usually have tongue-and-groove connections, so it's a good idea. I'd use construction adhesive or screws or both.
    Jan 15, 2017 at 15:26
