I have two switches in the livingroom that control the outlets in the room. We never use them and in fact since we swapped out all the outlets due to age, we didn't split them so they're hot all the time regardless.
I'm in the process of converting some switches into smart switches and already ran a 2 pole wire in my office to control the light and fan separately. I'd like to do that in the livingroom as well, only difference is there will be two switches for the light instead of just one.
What I've done so far is ran a second 2 pole wire from the ceiling fan down to one of the switches. So I have a black and white wire from the light (what I want to toggle). Currently the 3 way switch has three wires, one red connected to the traveler that goes to the other switch. One black that goes to the other switch as well, and another red in the common that's going to the outlets.
The other switch has one red wire and a black wire (black is in the traveler) going to the same source. There's a black wire in the common going somewhere else. Unfortunately I'm unable to determine where exactly everything is going on the second switch.
Any good advice is great. If more information is needed, please ask and I'll do my best to find out.
Thank you in advanced for any help.
