My AMANA (and another McQuay unit) in wall AC/heat pump unit works fine on cold days. However, I noticed when the room temperature is higher than the programmed temperature the heater starts letting in cold air. Ideally I would like it to just switch off until the room temperature drops below the programmed number. Is there anything I can do to achieve this desired behavior?
My unit looks is closed to this model but not exactly the same one
