New to Forum...Thanks in advance.
I had my painters put in a ceiling fan / light in place of a standard light. The light and fan function fine. There are 2 switches, one on either end of room, to turn on the power to the unit. The 2 pull chains at the fan / light control the light (off/on) and fan (3 speeds).
Making improvements to this room the last couple months, I want to put this fan / light on a dimmer. Legrand makes a Fan / Dimmer control switch. I have opened the current switch, and it is connected with black, white, and red wires to a grounded box. I have not yet looked at how the carpenter / painter wired the fan.
Questions - the new switches are for either single pole or 3 way, but they have many wires coming out of the back- pairs of black, yellow, green, and red...how do i connect this? And...can i use this Legrand Fan / Dimmer switch at each switch? I have been reading that you can only use one dimmer for one switch in 3 way switch applications.
the yellow tags for the one yellow cable and one red cable with the yellow sticker says 'use this in 3-way installations only.
