2-wire photocontrols vs 3-wire
A perfect photo-control has 3 functioning wires: Always-hot (black), neutral (white), and "switched-hot" (red). The photo-control powers itself 24x7 via the black and white wires. It switches power to the lamp via the red wire.
Incandescent bulbs have an interesting property: when they're not burning, they have very low resistance, and will flow current freely (this is called "inrush current"), That means if you're designing a photo-control, it's possible to skip the neutral wire, and have the photo-control power itself by leaking power through the bulb when it's off. This won't have any effect on an incandescent bulb. This is a 2-wire photo-control.
A raw fluorescent bulb is infinite resistance until the lamp strikes its arc. LEDs are high resistance until they light. (this is also true of any arc discharge light, including LPS, HPS, mercury, MH, or neon). All need a special control circuit to keep current from being excessive. These control circuits may, or may not play well with 2-wire photo-controls, and may be designed specifically to do so.
The same issue exists with dimmers, so "dimmable" can help.
Another option is to rewire your fixture to use a 3-wire type.
The types of photo control
source
This "puck type" is a replaceable photo control which sits typically on top of the light. It's commonly found on street lights, HPS, mercury or MH barn lights, and their LED replacements. They are universally 3-wire. The socket rotates, and the detector window should be aimed to the north.
source
If you look at most of the consumer grade photo-lights, you'll see a component that looks like this. This is a "stalk type" photo-control, and they are commodity items. It is replaceable, in the sense that it can be unscrewed from the fixture and replaced. They thread into a 1/2" trade size
hole widely used in electrical boxes. These are available in 2-wire or 3-wire.
So if your fixtures have this type of 2-wire photo-detector, you can pull down the unit, unscrew the old sensor, and screw in a 3-wire type. Wire black to supply, red to the lamp's hot, and white with the lamp neutrals.
You can put the sensor anywhere
Nothing says you need the photo-sensor to be at the lamp. Since the stalk-type can screw into any 1/2" knockout, such as that on the side of a junction box... you can install it where convenient - as long as it has a good view of an area whose lighting changes dramatically day to night. For instance, you could install it in an electrical box inside near a window.
Let the sensor "train"
Modern photo sensors have a memory, and "Learn" the day-vs-night brightness in their location, over several days and nights. I've installed a sensor on a north-side porch, so sheltered I needed a flashlight to work. I wasn't surprised when the sensor turned the lights on in broad daylight. However, by the second day, it had "gotten the rhythm" of what "light" and "dark" is in that location, and it worked properly. What does this mean?
If you are adding a photo-control near a switch -- if possible put the switch downstream of the photo-control (i.e. switch the red wire). That way the photo-control continues to get power 24x7, and it keeps its "memory".
Interchangeable for motion sensors
They also make motion sensors in the "stalk" format. So you could potentially alter the lamp to be a motion sensor instead of dusk-to-dawn.
