I have a outlet that is 240V with 4 wires. I want to change it to 3 wires, I am assuming the black is also a hot wire. With the volt meter I get 220V touching the two red wires and 110V when i touch the black to ground.
I want to change the plug to a 3 wire and I am not sure what to do with the black wire, can i just put a wire nut on it and push in the box?? Any help would greatly be appreciated. I don't need another shocking experience
enter image description hereenter image description here
    That is very strange that you're getting 110 volts from black to ground. What are you getting from black to each red? What type is your current outlet? How about a photo of the front of your current outlet?
    – DoxyLover
    Commented Dec 30, 2016 at 23:46
    Can you get us a photo looking into the back of the current box? Also, what type is that outlet? It looks like it can't be a NEMA 10 or a NEMA 14 from the back housing shown... Commented Dec 31, 2016 at 0:13
    What kind of device is that? If it is a range or electric clothes dryer, I though a 4 to 3 wire conversion is not in the spirit of electrical code.
    – wallyk
    Commented Dec 31, 2016 at 0:38
    What appliance do you want to power through this receptacle? Commented Dec 31, 2016 at 0:41
    @RonGinn -- can you please get us a photo of the front of the current receptacle? Commented Dec 31, 2016 at 16:12
It looks like your wires are in conduit. You need to follow the wires a bit more and figure out what they're being used for. They should go back to a circuit breaker, and it should be a 2-pole (240V) breaker. Turning off that breaker should turn off two of the wires. I have no idea what's going on with the third (black) wire.
Those are the two wires to put on L1 and L2 on your NEMA 6-20 receptacle. The ground goes to ground obviously. NEMA 6 does not use neutral.
  • That is what I thought, I did not think there was a neutral in 220 v.
    – Ron Ginn
    Commented Dec 31, 2016 at 4:16
  • and yes they are in conduit, and they do go to the 240v breaker, the black wire I am not sure but there is voltage there to ground 110v.
    – Ron Ginn
    Commented Dec 31, 2016 at 4:19
    110V to ground will be true for any "hot" in a 110/220 (aka 120/240) split-phase system. Ground is center-tap on the transformer (same as neutral by the way). The black wire is a real wildcard. What exactly was the old connector? I'm unclear why it has 3 hots and a ground going to 4 different terminals. Commented Dec 31, 2016 at 5:09
    Looking at the terminal connector on the ground are you in a country that has 3 phase power? If black to ground is 120 what is black to red 1 and black to red 2? On a 4 wire usually 1 is neutral, 1 ground and the 2 hotts. If it were 3 phase you would see similar voltages red 1 to black as red to black and red to red.
    Commented Jan 1, 2017 at 8:00
