I just finish building a desk. I already drilled holes prematurely (not deep, the table top isnt pre-drilled) and force my screw to fully go in.
It includes washers
that is meant to be between the table top and legs but I totally forgot about it!
Should I take it apart to put in the washers? If so, would I run the risk of having the screw not being able to screw tightly (with/without the washer)
The washer is about the 50% of the hole depth.
