I have a home that was built in the 1950's with an unfinished basement. I'd like to do a DIY remodel to the best of my ability, but am willing to hire a professional for some steps if a novice like me shouldn't do some of them.
The first step (as far as I know) is to buy a dehumidifier to remove any excess moisture, and once that has had some time to get to work (a week or so?), seal any cracks in the foundation and cement bricks. Is this the correct first step? If so, what is the best way to take care of sealing the cement?
Note, my home has a large hill behind it, and water comes down the hill after rain. It's only flooded once in the 23 years I have lived here, but often in the Spring water will get in through the cracks and drip down. Not enough to pool on the floor, but enough that it has left water marks as you can see here:
[Basement image 1]: [Basement image 2]: [Basement image 3]:
Obviously water damage is a huge concern once I've put all of the money into insulation, flooring, furniture, etc. I'd rather pay the price now than later. So, my question is:
Would it be better to hire a professional for sealing the cracks in the cement, or is this something someone with little home-reno experience (me!) can do successfully?
I can probably give you some general advice on basements from step 1 to 1000 but let's stick to the water issue.
So you have a hill slamming into your house, you get water consistently during heavy spring rains but very minimal in the basement, and there has been little to no significant flooding over the lifetime of the house.
In my opinion you can do all or some of these things:
  1. Regrade your yard. The hill coming down is fine. But you should have a good 6-7 feet near your house that is running away. You will need to grade your house to a notch on that side. I had to do this to my house and I went from having a pond in my yard a few times a year and minor water in basement, to nothing at all. I did stack french drains in the notched area (so I dug a good 6 feet down there). But again this is very cheap to do and the most important thing. Keep water away from your house.
  2. Dig a perimeter drain system (there are a lot of products that can help you do this) and have it feed to a sump pump. This is still very much DIY (1 day with a jackhammer) and cost is relatively cheap. However anytime you start tearing up your floor that has had no issues, you have more than 0% chance of having issues. Given the details you have provided I might dig a sump pump at the most offending location but I don't think I would dig out the perimeter floor.
  3. You can waterproof that side of your house. This is certainly very costly. Not a lot of downside to this other than it usually will set you back maybe 2-3k plus for just one side of your house. Again I think you have a grading issue and if that is fixed I think waterproofing may be overkill.
I would not suggest any sort of interior waterproofing including paints. Let your concrete breathe. Also I would suggest your framing is a good 1-2" from concrete and that you only insulate the top part of the walls. If there is minor moisture, giving it airflow will keep it from becoming an issue. The other thing is go with flooring that is either waterproof (tile or pure vinyl click-lock) or carpet that you don't mind possibly replacing (if you know that water is there carpet is easy to roll out of the way).
  • Agree mostly, but not absolutely sure if your #2 option is exterior or interior. If you aren't thinking about the exterior, perhaps consider trenching beside the offending wall, waterproofing/drain screening the wall from the outside, and installing drainage at the footer. My opinion is that this would be more effective than simply grading. – User95050 Dec 29 '16 at 14:18
You might want to use thoroseal cement-based wall coating on inside wall. Manufacturer claims it works on negative side too (to some extent, if used with Acryl60) and that it is breathable. The actual work is a little more laborious then simply parging the wall, and includes patching problematic spots with waterstopping cement, check manufacturer's videos.
Another (relatively, compared to positive side waterproofing) inexpensive option that I saw used is to put dimpled membrane on walls and floors first, thus allowing a little of incidental water to safely get drained.
