I have a 2-stage variable speed furnace installed with single stage thermostat. I would like to control W2 staging time delay using dip (DIP) switch settings on circuit board, but there is a sentence that confuses me. It could be my bad English. If you could help, I will appreciate it.
Manual reads as follows:
“Leave both switches off when using a 2-stage stat or enabling a W1 only call”
If I put both dip switches OFF (S7-1 and S7-2), does it mean that my furnace will never fire stage-2 and always be on Stage-1?
Following table is from the manual:
S7 Switches 1 & 2 for W2 delay.
Switch Settings | Options
[S7-1] |[S7-2] | [Time]
OFF | OFF | OFF
ON | OFF | 10 Minutes
OFF | ON | Auto
ON | ON | 20 Minutes
Note: S7-1 and S7-2 refer to dip switches.
Thanks!
