Our house used to have a wood burning stove in the basement. We also have a fireplace on the first floor of the house, leaving two separate vents in our chimney.
Before we bought the house it was renovated and a heat pump was added. As such, the basement wood stove was removed. The chimney vent for that stove is obviously still in the chimney so I was wondering if it is possible for a contractor to tap into that vent from our upstairs bedroom. The bedroom is directly adjacent to the chimney (behind drywall) but I figure if we can just tap into that vent it will save some time and money over adding a new stack.
I realize there are probably some building code restrictions in my area, but I am just trying to see if this is something that can be done?
  • Are you talking about adding a wood burning fireplace, or gas?
    – Steven
    Jan 6, 2017 at 18:40
  • Wood preferably, but gas would be a fine alternative
    – Matthew R.
    Jan 6, 2017 at 18:49
I will start by saying, if you're willing to spend the time and/or money, almost anything is possible. My gut feeling is that a wood burning fireplace would generally be out of the question without permits, engineer drawings and significant modifications.
A gas burning fireplace is definitely doable along an exterior wall using direct vent models, bypassing the chimney all together. Some models can also use the chimney and I would think that as long as your current chimney can provide the necessary clearances of the exhaust vent, it could be used.
