I have just installed new recessed lighting in my basement with exposed ceiling. That was the easy part. I happen to have a lot of traditional styled LED light-bulbs that I'd like to put in them. My problem is using these light bulbs, you can see bare metal when standing underneath them. Is there a good product or technique to cover the metal and make it look more finished?
Recessed Light
    Choice of the right fixture, or choice of the right bulb shape for the fixture you chose are the usual methods you have evidently opted to avoid.
    Dec 28, 2016 at 17:55
  • I will admit that I probably should have done a bit more research, but home improvement stores do not let you compare your options easily. I may have to buy the correct bulbs. I was hoping that there was another option is all.
    – caschw
    Dec 28, 2016 at 18:00
  • Most home improvement stores have quite liberal return policies, in my experience. Of course if you've mounted all the fixtures rather than taking one out of the box and putting a bulb in it and going "hmm" that may not be an option you wish to use.
    Dec 28, 2016 at 18:05
  • The easiest/cheapest/best-aesthetic way to fix this is to just go buy the correct bulbs.
    – DA01
    Dec 28, 2016 at 20:54
-1
You could cover the bare metal with paint. If you paint it the same color as the baffle (white), it should be less noticeable.
